Probably dumb question, because I can't remember the answer. But I don't have satellite hooked up to my Lynx. I mainly use it for the internet feed, but if I plug my Lynx into my car will the 2.0 channels work on satellite or are they made for the internet side?
Because the only way, I can hear them is whenever I plug my iPhone into the aux jack.
UPDATE: I found my own answer, if I want to listen to 2.0 channels. I'll just have to keep plugging in my iPhone to hear them.
What channel(s) in particular. In Satellite Mode you should be able to get all the Xtra channels as well. Meaning these ones. Xtra Channels - SiriusXM Radio
But you won't be able to get say BBC 1, which is only online.
I do see from the link, RockBar and Red White & Booze are couple of the channels I listen. I also enjoy listening to Y2Kountry, is that part of the deal?
I also notice that, the Live NFL Games "Sports Play-by-Play 861-892" is on there, how about the MLB, NBA and NHL team channels?
If so, then I want to install my Lynx in the car and cancel the Sirius built-in one.
Personally, I'd ditch the built in sub and go full tilt on the Lynx. One sub that you can take from home to car to work is the way to go. I'm cheap like that.
Wolf, the Xtra channels are exactly as name implies- they are extra channels you get on satellite only with the Lynx & Edge all listed in that link that Taylor posted:I do see from the link, RockBar and Red White & Booze are couple of the channels I listen. I also enjoy listening to Y2Kountry, is that part of the deal?
This should provide all your answers: Lynx Support page SiriusXM Lynx? Wi-Fi® Enabled Portable Radio - Shop - SiriusXM RadioWill "Tune Mix" skip any talk type station I have in the fav bar?
Do I have to worry about the battery and heat like I did with the S-100 and the S-2, I had to pull the battery and leave the back off, i actually got small cracks in the glass due to battery swelling.
Tom -
No heat issues that I've run into. I rarely record though, and I don't record in the car either. I know some people had trouble with the 100's and 2's recording in hot cars.
Every now and then I do have to pull the battery to get it to initialize to find the antenna, but it hasn't been as much of a pain in the arse as the 100's and 2's. I still really like the radio.
I'm the opposite. I want to get into the car and have it 'just work' without having to remember to bring something else along or have wires all over the dash, etc.
I have one of the SCC1 units in my Honda hooked up via the HON-SC1 interface and I like the simplicity of it.
That being said, I do miss the old features of Tune Select (which I think has gone by the wayside, now) and getting multiple lines of text and other info that you'd get on the PNPs.
I completely get the 'take it with you and save on the subs'-point, though.
Featured Favorite Channel PagesI was looking up couple of things about the Lynx and just notice this screenshot, I know the hearts are favorite presets, but what are the stars?
