Im new to this board, please forgive me if this is not the appropriate forum for this discussion but it is one of the few places I could find any discussions on the SC interface.
I decided to try sirius radio and picked up a Starmate5 (Hope sirius stays afloat).
My local shop had some SCVDOC1 for cheap (20$) and I picked up a couple. Ideally I was planning on installing in two cars using the SCVDOC1 and Clarion adapter and using the car kit with a power adapter for my home.
As I now understand SC connect mode it seems I lose many features (like replay), so I am debating returning the SCVDOC1 or perhaps better adapting it to use as a car/home dock for use with aux in. Seems it has a build in 12v-5V converter, and direct connection to accessory power (I dont want cigarette lighter power). Also this would allow for use with the MJS Gadgets SC-C1 to car PC adapter.
Pinout for the SC interface is shown in the user manual page 10:
http://www.tss-radio.com/images/SCVDOC1-installation-guide-110207a.pdf
1) Battery
2) Power Enable
3) Serial Data (RX)
4) Ground
5) Audio Right
6) Serial Data (TX)
7) Audio Ground
8) Audio Left
In posts in online forum it seems there is discussion on the SC DIN pinout and comparison between the home doc that has SiriusConnect/Home switch where the SCVDOC1 does not have this switch. So Im in doubt if it would be possible to use the SCVDOC1 as a car kit because it might come up in SC mode thus disabling the Starmate5 control.
I have following questions that I would be greatful if anybody has more info on:
1) Is the "power enable" signal of the SC DIN a way to control SC/H mode, i.e active (+12V?) then SC mode or inactive H mode? If not, what is this pin? Is there any other way to control SC/H mode so I can set it to H mode so I can use the DOC without the Clarion adapter to my head unit?
2) If I decide to buy the clarion cenet adapter to my head unit will this improve sound quality (i.e. does the cenet transfer audio digitally over the tx/rx interface, or is it still analog?)
I've always like toying around with electronics stuff and deciding if I should keep the SCVDOC1 units. Any additional info on this SC interface appreciated.
Thanks,
Kuma
1) Battery
2) Power Enable
3) Serial Data (RX)
4) Ground
5) Audio Right
6) Serial Data (TX)
7) Audio Ground
8) Audio Left
Thanks,
Kuma
