No sound after Stiletto install
cardana24
Jun 22, 2009
I have a Stiletto 100. I have car kits installed in all of my vehicles. I recently switched a previously working set up into my new car. I have an Alpine 7893 and I hook the SIRIUS up though the aux Ainet. So I have an Ainet to RCA plug, then from there I have a set of monster cable RCA to mini jack cable and then plugged into the dock. I have the power plug hooked up by a 12v socket behind the deck, and the antenna is hooked up too. When the car is switched on the radio comes on and it can pick up stations but nothing is coming though the speakers. When I turn the volume up all I can hear is my sub woofer thumping/clicking fromt he rotery dial being turned. What gives? Is my AI net port dead? Could a screwed up dock cause my problems? The radio works fine in all of my other vehicles. Has anyone else had this problem?
I would suggest plugging in a set of headphones into the audio out or line out jack on the back side of the dock while the stiletto is in it and it's receiving power. If you get sound through the headphones you know nothing is wrong with the stiletto or the dock it sits in. If that is the case I would think there is something wrong with your aux cables or the AI net port.
cardana24
Jun 22, 2009
Thanks for the suggestion. I will try the headphone later. Also I forgot to mention in the first post that I did make sure that the AUX setting is turned on. I'll post back with what I find.
