Loved songs going to slacker after update
sportboy
Dec 18, 2008
96
I assumed that if I "loved' a song and clicked on send to portable, after I did a update these songs would be in the G2.
For me, its not working this way. Songs that I've "loved" are not being adding to the G2. Even when I click on send to portable, they are not being added.
Weird.
Due to licensing not all of the songs can be copied to the portables. Usually those songs are grayed out and won't even let you add them to the screen on the web player portable section to be copied to the portable. I've never had a problem with it coping those songs that they do have licensing rights to though.
sportboy
Dec 18, 2008
96
I've never seen any grayed out as you mention. Every single song I've wanted to add to the portable, its allowed me to click ok and gives the message that this song will be added to the portable after the next update.
I have many that allow me to push okay and many that do not! The ones that do, always copy over, so I don't know. I had that problem before though, along with the issue of my stations not being copied to the device properly as they wouldn't play. So it took a factory reset to resolve that issue. Not sure if you are experiencing the same thing or not.
ibprtazpolpcp
Dec 10, 2008
I don't have a paid account so I may be misunderstanding, but I think this whole thread is a misunderstanding.
sport, "Send to Portable" means send the station to the portable. It has no applicability to songs and therefore no direct applicability to the heart "button". DAB, please correct me if I'm wrong.
No, if you have a Premium account, you can save songs via the web player. You can then send certain songs that they have license for to the portable G2/G1. So send to portable can apply to songs as well as stations. :)
