How to record web stream?
skuba
Mar 25, 2011
Hi, I usually listen to sirius on my commute to and from work, but I end up listening to the same part of the show. I would like to record the web stream so I can listen the entire show when I want it.
Do you know a way to do it on the Mac?
Casual Fan
Surprisingly nice
19,016
3,028
163
Roanoke, VA
Well, on a PC, and I assume it has to work about the same on a Mac, you can use a free program like Audacity to record the "line out" from your computer. Whatever you hear on your speakers is what Audacity will record. Then you can export it in AAC or MP3 or whatever format you like.
