Transfering songs between radios?
PFD305
Apr 6, 2009
After 3 1/2 years of flawless service my S50 decided to retire on me, the dreaded No Signal. I guess it is time to upgrade to an SL2. Is there any way to transfer my 500+ songs from my S50 to a new player?
First off, make sure you try a new antenna before you blame the radio.
Unfortunately, noone that I know of has cracked hthe Sirius song formats and been able to convert to MP3 or transfer between radios.
Your only way is to use PC recording software and play all 500 songs while recording them to MP3 through the soundcard input jack. It would take forever.
9,920
1,360
If you can play the radio through the computer's sound card, you might be able to save it as an MP3 if you have the input on your computer and a recording program.
