Stiletto newbie- WIFI question
crewguy
61
61
Bought a used 100. I activated it but cannot get internet radio. I am signed up at Sirius for internet radio. I have 3 radios activated so I deactivated one and activated the Stiletto. It connects to the router fine but says to connect to a satellite channel to update sub. Due to the rain- I have not had this radio in the stream much- just to activate and update channels. Do I need to expose the radio to the stream more before WIFI will work?
down4six
2,036
81
Southern Colorado
www.twitter.com
Did you set up an internet account for the stiletto? You have to have an internet account tied to the ESN in order for the wifi internet radio to work. I don't remember if it automatically links or you have to add the account info to the SL100 manually. Good luck!
You have to make sure that the internet radio is setup with the ESN for the SL100. Especially if you have multiple radios on the account. Usually only the primary will get setup for the internet access.
crewguy
61
61
That did it. I had to add internet radio to the individual subs. Now if I can get a decent set of headphones to wear outside while listening to satellite radio! Any ideas?
The SL2 headphones are much more comfortable than the SL100 ones.
