Stiletto/2 external antenna
jharrison29
Nov 17, 2008
13
I upgraded to a Stiletto/2 from an Audiovox. I have an external marine antenna for the audiovox which works very well. The Stiletto/2 tells me that the antenna is not detected.
The Stiletto works fine with a SIR-6 exterior antenna. But it won't work with the SRA-40 marine antenna.
Any ideas as to why?
Thanks, Jon
3,501
200
Hmm, I wonder if you connected the SIR-6 into it now if it would work. I wonder if when you put the Marine Antenna into it, it may have pulled out the connector. That's something we get a lot.
If the marine antenna has one lead it should work. It's definitely odd.
