Stiletto 2 battery charging
Phillip944
Feb 22, 2009
Hi,
I activated my new SL2 yesterday. Out of the box, the battery meter showed 52%. After charging for several hours, the battery meter showed 52%. After some usage and charging overnight, you guessed it... 52%.
Do you think I have a defective battery on my hands?
Any help would be appreciated... thanks.
Phillip944
Feb 22, 2009
That's the weird part. With the unit on and attached to the charger, the little lightning bolt shows on the battery meter. When it's off, there is a little light on the side.
7,752
Take it back to the store you bought it and do a straight exchange. I believe your battery is defective. Don't go through Sirius warentee replacement as you will get a scratched up refurbished product.
