Sportster 5 rewind problem w/ remote
Gladman911
Apr 23, 2009
Regarding this thread
The only time I can get this to work is if there is a big time period to rewind - like if I listen for 10+ min, then it (sometimes) lets me rewind. However, if I start my car/sirus, let it run for only 5 minutes or so and then try to rwd, it just automatically jumps ALL the way to the beginning. Then, if I try to fwd, it jumps all the way to current/live! VERY FRUSTRATING! My sportster 4 did not do this and would let me rwd even if I only listened to a minute or 2!
I have the same problem with the remote .. and it's damn annoying. Anyone know of the remedy?
semipenguin
Cheeseburger Connoisseur
8,998
Janesville, MN
My XMP3 doesn't have a very good search feature. I live with it...:)
Try resetting the factory defaults and see if that helps...:right:
The Butler
1,091
75
Canton-Massillon, Ohio
Try not releasing the button so quick. If you press and release the button it rewinds all the way. Holding it down will rewind in increasing increments. Only took me a year to figure out my unit worked fine and it was operator error. :eek:
