Slight problems using IE7
9,300
I think this is an IE7ism as I think Orbitcast has simular issues. The new TSS radio banner is cut off on the right side on the "d". It overlays (in front of) the doggy representing Sirius with only the back 1/2 of the doggy visible.
I will check it on IE6 at work tommorow.
Rainbow Sherbet WILL ALWAYS BE ICE CREAM!
8,832
Koop's Basement
I mainly use FF3 now, but I still have IE7 on my computer. So I just tried out IE7 and I didn't notice any problems with the new TSS radio banner.
Apparently this depends on your resolution and rather you are viewing full screen or not.
9,300
At work on IE6 I see the TSS banner fine. I see a quick flash of the XM but then that disappears.
I think it would likely work better is the Digital Radio Central graphic, the TSS graphic and the Sirius XM graphic were made as one graphic.
I am using 1280 x 1024 and it looks perfect on my LCD Panel. If I take the window though and start making it smaller, I can reproduce what you are talking about.
dlynx
411
Michigan.
www.btlsfan.com
I'm going to be working on the header a little more to get everything we want in there in a good format. The variable width makes it a major pain to get it looking good. Either you'll have a bunch of empty space (wide displays) or stuff cut off/cramped/missing with smaller displays.
Here's a better question:
Why do you still use IE?
Firefox is the way to go:
Firefox web browser | Faster, more secure, & customizable
It is very simple for me, I visit site even to this day that simply don't work very well with FireFox. It is just like at work, the states intranet, you can forget using FireFox. You can log in, but once you get in there, you can't do anything, the forms show up screwy. I realize this isn't a FireFox issue, this is a site issue, but they aren't going to fix it.
I personally have never really been that blown away by FireFox.
9,300
I notice there are no banners at all today. Is that by design or another issue?
Seems to me that the issue is under some configurations having 2 floating banners gets muddled. Having the one with TSS would be a good comprimize as it is highly unfair that he can't have a little banner given his support for this site.
