SL2 won't connect to WIFI
Vargas
Molon Labe!
3,426
153
Western, PA
I have the premium internet, have had it for a long time. I've never had a problem connecting with my SL2 before but today it just won't connect to my wireless.
The wireless is working fine because my laptop is connected. The SL2 will find my network, try to connect and then it just stalls. It never gets to the "checking.." stage.
I hope Sirius didn't screw something up with the recent premium changeovers.
Any help? I've done a hard shut down with the battery out a bunch of times and that did nothing.
9,286
Mine worked this morning. I would suggest you:
  • Do a full shutdown and restart of your SL2
  • Stop then restart your router
  • Delete your current WiFi entry on your SL2 and re-establish
When I had connection issues this procedure fixed it.
dlynx
411
Michigan.
www.btlsfan.com
I've noticed my SL2 is dropping it's connection fairly frequently lately. It will get to the connected point, then stall when you actually go to a channel. Restarting the Stiletto2 seemed to help a little bit, but still happens fairly frequently.
Same issue happens both at home on the 2 access points I have there, and the ones I use at work on a regular basis.
