SL2 USB Cable
mfrumkin
Nov 30, 2008
My new SL2 came in yesterday and the USB cable was left out. Tss-Radio is sending me a new one but does anyone know if I can get one at a local B&M store? It seems to be a proprietary cable, but maybe someone carries it? Any info would be helpful.
Mike
mynameisjamie
Mike
The Stiletto USB cable is usually pretty difficult to find around by itself. If you have a home dock or soloist then you would be able to use a standard USB with a mini plug on one end but by itself the Stiletto would need it's own USB. Hopefully the one you get will work out for you!:bigthumbup:
