SL2 update problems
Mrwirez
Nov 10, 2008
66
Pittsburgh
Is anyone else having problems with recordings since the new updates on their SL2?.
Since the new update last week, all my scheduled recordings have been screwed up but,
if I hit the love button it records fine though.
For example yesterday's Stern show came up "can't read file". Last night I set up a two hour test recording of the Stern show for this morning and the first hour did not record... Seriously I could care less about the pretty background pictures, I just want it to work.
Btw... I installed the software/firmware via the device recovery method.
Any ideas guy's?
10,739
I have not had these issues. I have been able to record and listen to my recordings. Perhaps you want to try another device recovery.
nafddur
Same here. I also went a couple of months without seeing the lockup-to-main-menu-while-recording problem until a few weeks ago (just before the update). Then - out of the blue - I had one lockup after using the buffer while recording. I'm anxious to see if the update has any effect on this sporadic problem.
But so far, scheduled recording and playback of recordings is working fine.
