Reputation Points
HarleyJoel
Oct 28, 2008
98
New Jersey Coast
It doesn't look like I'm able to add to anyone's reputation. I click it, add, press add to reputation and then the reputation stays at the same number. I click it again to see if it didn't work right and a pop-up tells me that I can't add to the same post. Am I doing something wrong or is it not working?
Reactions: TX WJ
8,693
Adding rep points rarely makes a visible change to that user to you. You can only see you're own rep.
Reactions: TX WJ
limegrass69
Confused
6,079
245
New York
You can't see how many rep points another user has. You can see their Rep power which is not rep points. If you give someone rep points, it most likely won't change their rep power.
semipenguin
Cheeseburger Connoisseur
8,998
Janesville, MN
If you click here, you can see how DRC members are ranked by Reputation...:)
See, look, SISO is ranked, um, well, not too high...:(
Keep giving SISO those Rep Points. He'll get up there...:D
Just how does BMF get ahead of Aaron?...:scratch:
almaniac27
Nov 12, 2008
395
17
Kent, Ohio
Bump.
How do you check who gives you rep points? My user CP only displays one from somebody, but it says I have ten. I know you start off with 10, but then I should have eleven or something, unless someone gave me negative points but I don't see that.
Jgatie
Banned
1,402
49
Bump.
If the rep point dot is gray, then they were not able to give you rep. It must be green for positive or red for negative. Gray just stays the same.
I want to fire off a warning about the rep points. It has been brought to my attention that some of you have been bombarded with neg reps by a select few posters. This is just not acceptable behavior here at DRC. If you feel you are being unfairly targeted with repeated neg reps by the same individual over and over. Please send me a PM so I can look into this.
I have fired off some PM's this morning warning some individuals about this. It is time to knock this nonsense off.
