Question - MP3's out of order when putting an album on SL2?
UncleScam
Jan 8, 2009
233
Springfield
Howdy all,
Quick question - is there any rhyme or reason to MP3's being in order when you transfer an album onto the SL2? Most of the time, it seems to work, but occasionally the songs appear in alphabetical order instead of the order they should be in. It doesn't appear to be related to the filenames or the track number in the MP3 tag.
Any ideas?
Thanks all!
siriusnj
45
Howdy all,
Any ideas?
Thanks all!
The only thing I can think of would be the track number in the tag. When you click on the specific album, it goes in order of the track numbers. All other times it goes in alphabetical order.
Vargas
Molon Labe!
3,426
153
Western, PA
It is someting in the tagging.
Download a re-tagging program and use this. I use this for EVERY MP3 that I download. It is kind of a pain to go through what you've already downloaded but to use it on every new download isn't too bad.
Grüpsaar
DRC Forum Bum
100
33
Anytown, WI
www.youtube.com
I just got a SL2 and noticed this also. When I goto an artist and view an album, it all shows up fine, but when I goto "all" by artist, and even if its the only album, they are in a different order. Not sure if this is the same issue you have.
Vargas
Molon Labe!
3,426
153
Western, PA
Sorting by Album, if you tags are correct will put the songs in ORDER as they appeared on the album.
Sorting by Artist and then All will put them in alphabetical order.
UncleScam
Jan 8, 2009
233
Springfield
hey all,
first off - thanks a ton for the help.
do you have a re-tagging program that you'd recommend? i never knew such a thing existed...
thanks!
