Need help with Slacker!
Bandit 5160
Oct 31, 2008
323
How do I find custom stations that others have created and listen to them? I am having a hard time doing this.
Bandit 5160
Oct 31, 2008
323
Out of Control:
Thank you for the help. I got me about 25 custom stations now on Slacker thanks to your links. Slacker can really help enrich one's musical experience!
SatRadioRules
Oct 21, 2008
57
Out of Control:
IF you have a 25 station unit, you may not want to have 25 stations on it. It's my understanding that for each station, the refresh throws 100 songs. If you listen to a channel for longer than that 100 song period, on the next refresh, it will add songs to that channel to reduce the chance of repeats. Yes, it actually is smart and looks at your listening happens! By using less stations than the unit can hold, you are freeing up space for additional tunes.
Pretty cool, actually....enjoy!
Bandit 5160
Oct 31, 2008
323
I don't as of yet have a unit...I just listen online. But thanks for the advice for when I do get a unit...which will be the first thing I do should Sirius-XM go belly up. Even if sat. radio, which I listen to in my car mainly, DOES survive (which as of now seems to be less and less likely), it would still be nice to have a Slacker G2 thingie.
