Is it possible???
plb139
Is there a way I can transfer songs I downloaded from Sirius on my Stiletto 2 to my IPod? I want to put the History of Howard Act 1 on my IPod before Act 2 comes out at the end of December.
If you have any ideas please let me know. Thanks in advance
DoublEE
40
54
South Euclid, Ohio
Not directly. You have to record them in real time onto your computer in MP3 format, then transfer to your iPod
8,693
I don't have a Stiletto, but have you tried fooling around with the MSS software?
SIRIUS Satellite Radio - MSS Studio Stiletto
Also, make sure you're up-to-date with the software.
That's really all I can think of. :s
This software is primarily useless. Good for software updates. That is about it. If you have good WiFi you don't even need it installed.
The SL2 protects its internal recordings pretty well. Doing it as others have suggested is about the only way.
DoublEE
40
54
South Euclid, Ohio
How would I do that?
You need to connect your Stiletto's audio out (headphone jack) to your computer sound card's audio in. Then use a program like Roxio or Audacity to record in realtime through the sound card into a format that is compatible with your iPod.
