Inno and Car Dock
geosync
2,055
395
88
Portland, Or
I recently installed a car dock in the auto for my Inno. Weird issue, I can't turn the device on with the remote. ?? Remote works turning it on while in the home dock. I can turn it off with the remote while in car dock, turn it on and off manually on teh device, but can't seem to get it back on with the remote. If I turn it off, and pull it off the dock and plug it back in, 50% of the time it comes on automatically. Sometimes it takes a couple of re-docks to get it back on. Anyone have this problem??
goreds2
5,906
767
OH H.....EYE OH
I think most car kits are made for the receiver to be manually turned on. Does your home kit when installed have the receiver saying BATTERY CHARGING? When in the car kit, it probably does not.
The MyFi in my truck is the same way. I have to manually turn it on.
geosync
2,055
395
88
Portland, Or
Yeah, I think ur right, it doesn't charge when on the car dock. I guess it only draws juice once it's turned on, but manually. Not a big deal, thanks.
