How many antennas have you gone through?
Vargas
Molon Labe!
3,426
153
Western, PA
I've been a Siriu subsciber since September of 05 and have gone through at least 5 or 6 antennas.
The latest of which just konked out on me two days ago and I have NO replacement.
I know that nothing is perfect but this is just ridiculous.
How many have you gone through???
HomieG
318
Believe it or not, zero antennas in four years. And one is a micro-dot!
jwt873
112
The antenna in my truck and my home antenna have been going strong for six years now.. (I subscribed to Sirius in Feb/03).. The micro-dot antenna in my car has been working for 2 years.
I've never had an antenna fail.. (Knock on wood :) )
Reactions: semipenguin
2+ years... No antennas broken yet.
Although I only use the microdot on road trips, a handful of times a year.
14,815
I think I'm at 3 years, and also knocking on wood, haven't had to replace any yet.
I have a good external antenna on the outside of my house, a window sill antenna at work, and a dot on my trunk lid. I always move it into the trunk when I go through the car-wash.
dawgstar50
Feb 11, 2009
Is it my antenna?
First time poster here. I've been having a very hard time holding a signal on my S50 all winter. I was thinking maybe I was just in a bad position to be picking up the satellite or the radio itself was taking a crap. I'm using the dot, so you guy's have me thinking it's the antenna. I'll try a new one to check. There's to much going on now that isn't on the regular airwaves. Thanks
In my over 9 years as a subscriber using Sirius and XM for a long time in both my personal and company car. I've probably gone through 5 or 6 antennas. These were installed properly where they were not be crimped, but the reception would get worse and worse to the point I'd just replace them. The reception would return to normal for a long while, but would eventually get worse over time.
I will say this, I've had much better luck with XM antenna's than Sirius ones. Out of those 5 or 6 that I've replaced only one was an XM antenna.
zepped
Nov 2, 2008
234
In about three years I've gone through at least six. I had a weird setup that caused me to move the receiver and accompanying antennae numerous times a day and the wear and tear just ripped them apart. I even bought insurance on the antennae through Circuit City and saved some bucks because I was eating them up quickly.
I've had a more permanent set-up for the last year and happily still have my original antennae from when the new set-up was installed.
GordyMac
Jan 19, 2009
58
www.droidtvforum.com
I've went through several radios (just upgrading and whatnot by choice) but only ever had to replace 1 antenna on its own.. have 3 active radios too.. a big part of it is moving the antenna from car to car
dlnester
407
35
Overland Park, Kansas
I signed up for Sirius Dec. 26, 2004 and I've gone through 2 antennas on my car. None of them are dot micros. The first one didn't fail, but it was getting water inside it so I elected to change it then instead of waiting for a failure. I think I have 2-3 dot micros in the package in the closet waiting.
