46" LED (45.984375" diagonal size) TV with Full HD 1080p (1920 x 1080) resolution for the sharpest picture possible
UltraBrilliant LED system includes a unique "double-dome" light amplifier lens and multi-fluorescents, enabling high brightness and color purity. The system features full array of LEDs evenly dispersed behind a diffuser, resulting in more uniformity
Full HD 1080p X-Gen LCD panel with 10-bit processing is designed with advanced pixel control to minimize light leakage and wider aperture to let more light through, providing the industry's highest contrast level (Spectral Contrast Engine MC).
120Hz Fine Motion Enhanced for the ultimate in fast-motion picture quality
Wide 176 Degree Viewing Angles - Sharp AQUOS LCD TV viewing angles are so wide, you can view the TV clearly from practically anywhere in the room
AQUOS LINK™ enables convenient control of AQUOS Blu-ray Disc™ players
High Brightness (450 cd/m²) - AQUOS LCD TVs are very bright. You can put them virtually anywhere – even near windows, doors or other light sources – and the picture is still vivid
AQUOS Net delivers customized Internet content and live customer support via Ethernet, viewable in widget, full-screen or split-screen mode
USB Photo Viewer with Music Player enables enjoyment of high-resolution digital JPEG images and MP3 music files
More features
100,000 hours LED life (The typical period of time after which the lamp's power output will have decreased by about half, given that the AQUOS LCD TV is used continuously in a 77 degree Fahrenheit room under standard lighting and brightness conditions)
20 watts audio system (10 watts x 2)
ATSC/QAM/NTSC tuning system
16:9 aspect ratio
4 milliseconds response time
Energy Star® qualified model - Consumes 90 watts, exceeding Energy Star® guidelines by 63 percent
Inputs and Outputs
4 HDMI™ inputs (version 1.3 with deep color)
2 HD component inputs (1080p compatible)
One 15-pin D-sub PC input
One 4-pin DIN S-video input
2 composite video input (audio/video)
One RS-232C
4 RCA L/R audio inputs
