From .avi to DVD?
Vargas
Molon Labe!
3,426
153
Western, PA
How would I do this?
I downloaded a large 900MB torrent and I want to put it on DVD and the torrent is an .avi file.
I use Handbrake but it doesn't take an AVI and turn it into an .ISO or a Video TS folder.
I feel like I'm missing something really obvious here.
Any help is appreciated.
Vargas
Molon Labe!
3,426
153
Western, PA
Can you convert the avi to something handbrake can convert to an iso, like an mp4?
Well, I guess I can take the .avi and use handbreak to make it an MP4 and then use handbreak AGAIN to make it a DVD.
I will try this.
I found a program online, avitodvd but I'll be honest with you, I just cleaned up my harddrive and I've loaded about 5 new programs all to convert video and load files on my new PMP and I just don't want to use another one.
I'll report back on the handbreaking.
memebag
Top Brass, ADVP
5,814
Lake Huntzing
Maybe you're missing a codec. Can you play the AVI file from Nero? Do you know what codec it uses? If not, ffdshow will tell you.
Vargas
Molon Labe!
3,426
153
Western, PA
I must be missing that codec. I will do a search for it.
Thanks for the help---what a pain in the a$$ all to burn a stupid dvd for my 6 year old.
eth555
Nov 10, 2008
20
Not sure if you have Windows Vista or not, but I just burned a couple of avi files to a dvd using Windows DVD Maker. It took a while for the computer to convert the file but it worked better than I expected it too.
Vargas
Molon Labe!
3,426
153
Western, PA
I do not have Vista. I am using XP sp3.
But thank you.
