Ford OEM Help, Please
Sirius Rich
33
Houston
I had a Ford friend ask this question:
"I have a 2006 F-150 SuperCrew with the Audiophile 6-Disc radio with Sirius satelite radio. I had to disconnect my battery today and when I reconnected the battery I no longer can get the satelite radio to work. My radio is equiped with the AUX button in order to switch to Sirius. When I press the button I get a message that states "no aux audio".
I told him to check the fuse, if there is one, from the Sirius receiver box. I also told him I am guessing. Any knowledgeable OEM members here?
no1hedberg
335
West Virginia
Wow that doesn't sound too good. Please correct me if I'm wrong, I think the head unit, and the sat tuner are on the same circuit, so doubt a fuse a blown, but certainly doesn't hurt to check. This may be overly simple, and probably won't work, but did he try to power down the head unit with the battery reconnected, and power it back on. This may force the head unit to rediscover the sat tuner. The other options I can think of would be check the wiring harnesses. Turn off the HU and disconnect and firmly reconnect the wiring connections, then re-try. I believe the sat tuner on that truck in behind the radio, behind the glove box, or behind the passenger side kick panel. Good luck.
limegrass69
Confused
6,079
245
New York
Going out on a limb here, but is there a diagnostic menu on the head unit where you need to input a selection that tells it that there is something specific plugged into the aux port? Maybe the HU doesn't have the ability to auto discover the sat tuner.
no1hedberg
335
West Virginia
I forgot.....Every once in awhile my Edge says sat fault, and doesn't work. Cycling the key off for 10 or 20 seconds fixes the problem. Doubt it's helpful, but doesn't hurt to try.
