FM-MOD02 and FM Direct Connect
kryptonite
9,306
1,181
I have one of those FM Direct Connect units from several years ago. I feel like I've asked this before, but if I want to buy an FM-MOD02 for iPod or phone into my car, can't I just connect the two devices without having to undo the whole front end of my car??
Car antenna --> FM Direct Connect --> FM-MOD02 --> phone
(Cheesy diagram)
[ame=http://www.amazon.com/Scosche-FM-MOD02-Universal-Modulator-Satellite/dp/B001QBG614]Amazon.com: Scosche FM-MOD02 Universal Audio Input FM Modulator for iPod, Satellite Radio or Portable Music Player: MP3 Players & Accessories[/ame]
3,501
199
They pretty much both do the same thing but you wouldn't be able to use both at once. If you use the FM-MOD02 you can use it for other devices and for your Sirius radio. But can't use the FM Direct for other things besides a SiriusXM radio.
kryptonite
9,306
1,181
So I'd have to remove the FM Direct or could I connect the FM-MOD02 into the FM Direct where I would normally plug the Sirius dock?
3,501
199
You would have to remove the FM Direct and install the FM-MOD02. Then you would need use audio cables to plug in your Sirius radio or other devices into. But just DON'T try using both the FM Direct and FM-MOD02 at the same time. Not that anything bad would happen, just not meant to do that.
