Connection Error - Stiletto 2
Discussion in 'Sirius Portables' started by therookie911, Dec 23, 2008.
  1. therookie911
    therookie911 New Member
    I installed MSS about a year ago without error. I used it a couple times without error, until last night. When I plug in the Stiletto 2 I get a "Device Failed Connection" sound through my speakers. (Double beep) The computer will not recognize my Stiletto. I thought something was wrong with my unit until I installed MSS on 2 separate laptops without a problem. When I plug in the Stiletto to either of the laptops it is recognized and I'm able to transfer songs. My desktop has stopped working. I've tried 4 different USB ports on my desktop. I've plugged in other USB devices and the ports are definitely working properly. Any IDEAS???? :confused:
  2. MM
    MM Administrator
    What OS are you using? XP? Vista?
    Maybe you should trying reloading MSS. Delete what you have and download the newest on from Sirius.com.
  3. down4six
    down4six Well-Known Member
    I have problems like that with my desktop with Vista, I just kept re-plugging and re-plugging and eventually it worked. Hang out around here and you will hear how clunky MSS is. I think most people just use it to install firmware updates on their stilettos. Good Luck!
  4. IdRatherBeSkiing
    IdRatherBeSkiing Sherbert is not and never will be ice cream
    Do a complete reboot of your SL2 before connecting. This fixed it for me the only time it has happened.
