Can I use a this home power supply?
JeffNY
Dec 14, 2008
Hi, I have an ST2 that I have been using in my home for three years with a power supply (AC adapter) than I got wit the home kit. It says:
INPUT: 100-240V 50-60Hz 0.4A
OUTPUT: 12V (a solid line over a dashed line) 1.2A
MODEL NO: ACTM-09
....we just had a huge power outage from ice. It now appears this AC adapter does not work. Well, it powers the radio sometimes until I plug in an antenna. I tried the radio in my car and it works fine.
I am trying to get another AC Adapter for my ST2 pronto. I have an AC adapter here for a battery charger that has the same kind of plug. It says:
PRI: 100-240V 50-60Hz 330mA
SEC: 12V (a solid line over a dashed line) 1200mA 14.4VA
Can I safely use this adapter to power my ST2? They are very similar, the only thing that concerns me is the "14.4VA".....
HELP!
Thanks,
Jeff
JeffNY
Dec 14, 2008
Ok, I am back up and running using this other AC Adapter. Can any of you electronics experts tell me if I can use that 1500mA AC adapter above? The radio will only draw the amperage it needs, correct? So upping the available amperage from 1200mA to 1500mA should not cause any problem?
Sorry if I am talking to myself here :) Thought the info might be of help to others
fineware
Nov 8, 2008
38
Remington, VA
You should be ok. The 14.4VA is redundant: 12V * 1.2A = 14.4VA. Actually, the current rating just needs to be at or greater than the required drawing current. The voltage and polarity is more important. For example, you don't want to use that power supply with an S50 since it needs a 5v power supply.
JeffNY
Dec 14, 2008
>>You should be ok.<<
....thanks. I was using my battery charger AC adapter today but I did buy the Radio Shack AC adapter above. I will try it on my other ST2 (from my car) but it sounds like it'll be fine. The ST2 in my house I have connected to a computer to record Howard Stern everyday...so I can use my iPod to listen to shows :) I had two ST2's and a spare antenna...but no spare AC adapter to swap out if it failed. I should be set now.
